electronic ignition - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 07-03-2013, 08:17 AM
electronic ignition
Hello to all, I have a 67 Chrysler with a 440. A friend gave me an electronic ignition from a later 440 distributor, electric box, and resistor. My question is can I use the old point coil or do I need to go with say a MSD blaster. Just don't know if there is a different OHM factor between the point coil and one for electronic ign. Thanks Atlas
Old 07-03-2013, 12:38 PM
LATECH's Avatar
Dont use the points coil .
You dont need a blaster, but IIRC the ballast is 1.5 OHM so get a 1.5 ohm coil , blaster or whatever and you should be good to go.
Fact is stranger than Fiction
Old 07-04-2013, 07:23 AM
Thankyou, I knew it was different for Harley's and that's was I questioned it. I did not know the ohm value. I love this website with so many people that have such great information. Thankyou again Atlas
Recent Modern Electronic Engines posts with photos
Electronic Ignition. DrBee8457 Engine 1 05-31-2006 01:45 PM
electronic ignition 65chevy4x4 Electrical 4 09-05-2003 06:19 AM
Electronic Ignition 85f250 Electrical 4 07-29-2003 01:24 AM
electronic ignition mecha Electrical 0 07-25-2003 04:38 AM
electronic ignition? 65galaxie500 Engine 4 11-10-2002 03:28 PM
