Hotrodders Bulletin Board
#1
electronic spedo problem
have a 1995 f150 the spedo does not work also odometre not working and abs lite on,as ther is no sending gen in trans(5spd std.) is the sender in diff actuat all3 functions. apreciat any help. cliff
#2
re: electronic spedo problem
rear axle speed sensor probably screwed, check the harness, as well 'cause they are known for getting snagged/ripped off/and otherwise screwed too.
#3
spedo not working
re my request for help on f150 spedo electronic, new sensor on rear axel fixed spedo , but abs lit still on. thanks for the help. any ideas how to clear the abs lite. brakes work fine. thanks again cliff
#4
Doc here,
On the ABS lamp, My Suggestion would be Have that Checked.. Other than A "Glitch" It may actually be a safety Issue that needs addressing, or it may be something simple as a Code reset..But it is better to be safe than sorry.. Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
Back to top |
Similar Threads for: "electronic spedo problem"
| Piston/valve interference problem | jameskirk1 | Engine | 12 | 12-03-2004 04:14 PM |
| Puzzling temperature problem on the hemi solved | Centerline | Engine | 2 | 11-26-2004 03:48 PM |
| Temperature Sending Unit problem | Centerline | Engine | 3 | 11-12-2004 05:13 PM |
| spedo problem | Brian Morency | Electrical | 4 | 10-27-2004 02:23 PM |
| 68 Camaro Starting Problem | jctrayer | Electrical | 5 | 10-27-2003 01:12 PM |
