Electronicly-shifted manual transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2005, 03:03 PM
alex_0227's Avatar
Skater dude
Can someone tell me a little bit about electronicly-shifted manual transmission, so you could have shfter buttons on the steering wheel? I live neer a city so driving here with a manual tansmission wouldn't go too weel cuz there's stopligthst everywhere.
Alex
Old 04-04-2005, 05:07 PM
poncho62's Avatar
Wiki Edits: 5
Shifting is half the fun, man...........................get an automatic, then.......................
Old 04-04-2005, 07:36 PM
segge's Avatar
The Ferrari's or Lamborghini's have that kind of system, forget which one, but then again if your spending that much on a car you want them to put some cool features into them.
Old 04-04-2005, 07:41 PM
It is not easy to do unless you are working with a sequential transmission (like on a motorcycle).
Even then you have to figure out how you are going to shift without the clutch. To upshift you would need to at least kill power to the motor (ign. cut). To downshift you need to 'rev-match'. Are you going to do that automatically (with an electronically controled throttle or ETC) or are you going to blip the throttle each time you have to downshift. How long are the drive dogs (no syncro's in a seqential trans) going to last while you learn to blip the throttle?
The next thing to look into is what is going to actuate it. Electronics can only handle so much...you will most likely have to use some type of pneumatic or hydraulic actuator...which means at the least adding an air compressor (or using CO2 cans).
This isn't something the average 'Joe' can jsut slap together on the weekend.
Take a look at this trans
http://www.quaifeamerica.com/transmissions/rwd/15g.htm
Too bad it is $13,195.00
Old 04-04-2005, 07:46 PM
alex_0227's Avatar
Skater dude
Aight than forget that. Just go with the regular manual.
Alex
Old 04-04-2005, 08:55 PM
x007's Avatar
Supercharged T/A
Alex
Get a 4l80 & a compushift, then you can program the trans.
to respond on the fly to your need, as well as Up/down shifting whit two button if needed
You can run Whit an Overdrive transm. whit normal shift then on the track you reprogram the trans. to shift at 6500 for example..
This is the best of both world
-= Build for Power =-
Old 04-05-2005, 06:29 PM
Here is something kind of like your talking abotu but it is for a automatic. Paddle shifters http://www.twistmachine.com/
Best manual transmission? cojohnso Transmission - Rearend 2 09-14-2004 07:26 PM
54 223 Ford 3 speed manual transmission Neal0o Transmission - Rearend 0 09-17-2003 11:55 AM
Manual or Auto transmission? '54-Hunter Hotrodders' Lounge 20 01-12-2003 08:07 AM
Chev 400 Small Block & Manual Transmission JohnT Transmission - Rearend 4 10-03-2002 06:58 PM
Manual Transmission on a 1985 Olds? Andrew7dg Transmission - Rearend 0 07-25-2002 08:46 PM
