Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eliminating bumper bolts
Old 01-02-2005, 06:53 PM
Ratchet's Avatar
Ratchet Ratchet is offline
Last journal entry: Ontario Camaro Nationals 2008
Saw them doing this on overhaulin on the boob tube.
They put the bolts in the bumper and then put a washer over the bolt from the backside and welded the washer to the bumper and the bolt to the washer then they ground the head of the bolt off and welded all around the front side and ground the weld down to smooth it in.
They said the washers were used to add strength.
