Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eliminating bumper bolts
Old 01-16-2005, 02:27 PM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Last journal entry: Vise jaws
I would still put a washer and nut on the backside before welding. Do as Willys stated but the nut will hold the washer flat and the washer will let it lay perpendicular to the bumper. You will have to hold it against somehow until you spot the front, then weld from the frontside solid. You don't have to weld the washer and nut but just use it as an aid for alignment.
