eliminating kickdown cable on a turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2012, 07:58 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
I want to eliminate the kick down cable on my 350 turbo .I have seen this done,but dont' know how to go about it. I know the hole can be plugged with a small soft plug,but what about the part the cable hooks to in the transmission ??
Old 08-24-2012, 08:18 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I believe you have to remove the pan and then remove a "C" clip to get that out where you can install the plug.
Old 08-24-2012, 08:22 PM
39 chev's Avatar
Thanks for the reply.I am installing an aluminium pan,so I will have access,do you know if I have to drop the valve body to get to the C-clip??
Old 08-24-2012, 08:53 PM
350 kick down
no you dont remove clip and plug hole
The Following User Says Thank You to anglia427 For This Useful Post:
39 chev (08-24-2012)
Old 08-24-2012, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
When you remove the pan from the trans.
here is a photo of the reataining clip and lever of the kick down internal linkage on the valve body.
The Following User Says Thank You to Crosley For This Useful Post:
39 chev (08-26-2012)
350 turbo kickdown cable? bigj7698 Engine 1 10-31-2011 01:20 PM
turbo 350 kickdown cable yragat Transmission - Rearend 2 09-02-2010 11:39 AM
Turbo 350 Kickdown Cable tommer2 Transmission - Rearend 2 08-06-2009 12:37 PM
Eliminating the kickdown cable from the T-350 transmission Richard Locke Transmission - Rearend 16 01-31-2009 10:43 AM
changing kickdown cable on 350 turbo? badriand Transmission - Rearend 7 07-12-2007 03:54 PM
