Frisco: I want to thank you for the link to Cal Trac and the information about fabricating them at home.
I took the fabrication idea a little different direction. I welded a drop-down bracket onto each side of my axle and hung both my shock absorbers and a connection point for the traction bar on the bracket. The bracket aligns with my frame rail forward of the axle. I then welded a bracket onto the bottom of the frame rail. I made a reinforced "L" bracket (Bell Crank) which pivots on the frame bracket and ran the link back to the differential bracket with a an adjustable ball joint on each end. On the top of the "L" bracket I mounted a sturdy rubber bumper. So I adjust the traction bar length to the point where the rubber bumper nearly touches the frame.
It works great, there is still normal suspension travel, but under acceleration, the differential winds up a very small amount, the rubber bumper contacts the frame rail and the torque lifts the nose of my truck about 2". There is absolutely no further rotation of the differential.
