Embossed Shim Head Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2008, 03:25 PM
Well, just when I get one problem solved, up comes another one. I just received the head gaskets for my motor and since I needed to tighten up the quench area and pull my compression up, I needed to use a shim style head gasket instead of a composite that I am used to using. What I got come from Jegs is their Embossed Shim w/Rubber Coating and is a thickness of .024" for my SBC. My question is this, how do I install these? They came with no instructions at all and I honestly don't know what to do with them. There is nothing on the gasket to indicate which is up and I don't know if they are installed dry or what. I called them, Jegs, and the tech guy I got was no help at all and I really don't want to get this together and find out I screwed it up. Any help would greatly be appreciated. The part number is 555-210044 in Jegs. Again, thanks..
Old 06-28-2008, 08:35 PM
Thanks for the reply, I just wanted to be sure on the correct way to install them.
Head Gasket or Piston Rings? 94dangerranger Engine 7 03-24-2007 02:33 PM
honda 2.0 head gasket jerw55 Engine 9 01-29-2007 10:43 PM
Head gasket question? GMW Engine 7 04-06-2006 02:37 AM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 11:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 12:33 PM
