Emergency brake cable que. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2004, 06:47 PM
My emergency cables from my rear wheels are complete with the knob attached at the end of my wire cable. What is the easiest way and best to put these together to bring them up front to attach? Is there a schematic or anything that I can print out to follow? I have to keep things neat or it drives me crazy. Thanks Dana
Old 10-17-2004, 10:29 AM
MI2600's Avatar
Member# 3287
What kind of car?
Old 10-17-2004, 05:16 PM
Rear end is from a 1970 chevelle and it's on a 39 chevy!
Old 10-19-2004, 08:24 AM
Dave E Shank's Avatar
HEY 39: I have a Buick Regal rear end in my street rod. I have a Genie Shifter independent emergency lever mounted on the 350TH transmission. It has two cable clamps on the end of the lever to attach the cables from each individual wheel. You adjust the linkage to get an even pull from each wheel. It works well. Lokar www.lokar.com also sells an independent emergency system....DAVE
