Trying to hook up the emergency brake cable on my 40 ford coupe with a 9 in rear and ford disc conversion kit. A cable off a 96 explorer has the right ends but I need to shorten it and would like to know where I can get a replacement end for the cable. (ferrule) Thanks.
I have shortened cables and then re-hooked them using cable clamps ... not the neatest solution ... but it can work and not be very noticeable ... if you splice in a not obvious place ...
Thanks for the thought Deuce. I will have plenty of cable so it could be possible to shorten the housing and clamp it together leaving both ferrules on the ends.
Rich
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
