-   -   Emergency Brake Help. (http://www.hotrodders.com/forum/emergency-brake-help-92348.html)
Gr8 '48 bow tie 06-23-2006 10:40 PM
1948 Chevrolet Fleetline Aerosedan.
I need to locate emergency brake cable boots. They are 4 or 5 inches long and about 1/8" opening on one end and about 1/2" on the other. They fit on the cable and onto the protector cover just before the back axle. I also need rear shock absorber kits. The shocks are OEM lever type.
Thanks Al
Deuce 06-25-2006 10:01 AM
The type rear end you are using might be helpful information to someone helping with your search ... :)
Gr8 '48 bow tie 06-26-2006 11:22 PM
I am using the original '48 cable. The rear end is out of a '75 camaro. I have only tried Auto Zone for the boots so far, I will check with NAPA and see if they have them or can get them.
Al
