EMERGENCY! Coolant frozen in block, need to thaw
Went to the garage this morning and the anti-freeze has frozen and worked it's way out of the radiator neck. Lower radiator hose has slushy fluid, not completely solid. It's 33 degrees right now, and will drop by 5pm, so I need to find a solution within a few hours.
I don't know exactly how to proceed - hoping someone has some advice. Thanks! |
Get some decent antifreeze.................That stuff you have in there is straight water if it froze.
Does the engine run?...If so, warm it up with a heat lamp, Once its just water again, change the coolant and put antifreeze in it. If not running, drain as much coolant (water) out of it as you can and pour some antifreeze in it.
Ontario Rodders |
Thanks for the advice, I'm heading out right now.
I bought the car about 4 months ago and then topped it off with about half a gallon of 50/50, but there must have been straight water in there from before. I have 50/50 in my other vehicle (which is sitting right next to it) and no problems there. I appreciate the help! |
If anyone is still reading this thread - this car is in storage for the winter, should I drain the coolant and leave the block dry?
Drain the block and fill it with a 50/50 mix. If you dont the inside of the block will rot and it will also freeze.
The block will rot??
i would suggest running a hose from the hot water tank in the house out to the driveway, and flush the system with that to melt away as much of the ice as possible
once you have a system that will allow coolant to pass through freely, you can start the car to use engine heat to melt anything that remains after that, you can redrain the system and add a proper 50/50 mix the "slush" that you found in the lower hose was a poor mix of antifreeze & water. not enough water to totaly freeze, not enough antifreeze to keep the water from freezing also, for all future reference, straight antifreeze WILL FREEZE FASTER then a 50/50 mix! .... nature of the beast |
As a Canadian from the great white frozen north, I can tell you that straight antifreeze does not "freeze" per say, but does get too thick to flow properly at colder temps. It just turns to gel, but it won't expand like water and pop your freeze plugs or crack the block. Mix it 50/50 like the directions say and it'll be good to -40 or less. Below that, you will get some gelling again.
lol... straight antifreeze freezing? i'd have to see that. the propolene glycol does not freeze. trust me. frigid ohio winters has taught me that much. 0 degrees for a week straight and it still isnt froze... come on. where did you people take your chemistry classes? BUT... like diesel fuel, it does get thick. doesnt freeze, but gells up slightly. but as soon as its warmed it goes back to the same consistency.
^^^ i was talking about ethylene glycol actualy
pure ethylene glycol freezes at 8° F (eight degrees ABOVE zero) For ethylene glycol the maximum protection is at 67% ethylene glycol in water. A ethylene glycol solution of this concentration will freeze at -84° F once you start adding MORE ethylene glycol, the freezing point starts to rebound back UP .... very quickly |
absolutely correct. It is called the eutectic point.... about 2/3 antifreeze..... 1/3 water. By the way, for those of you in sub zero climates..... don't forget the chill factor of air through the radiator..... If your antifreeze is good to 30 below and it is 20 below air temp , when the fan starts the radiator might freeze. Raised in the North..... uh huh. As for the car...... I would start it. If the water pump is not frozen, run for a 5 minutes, let her sit 10, then run it another 5, etc.... til she thaws. Alternate is to put a 100 watt bulb next to the block and radiator and cover the engine with a blanket. |
| Why is the Ford 302 block better than the 351W? | BarbWire | Engine | 63 | 06-01-2006 05:35 PM |
| need info on small block chevys | engine-rookie | Engine | 1 | 05-03-2003 08:48 PM |
| small block vs big block | JUSTINH | Engine | 28 | 02-17-2003 04:37 PM |
| big block or small block ford? | stangfiend | Engine | 3 | 12-10-2002 09:55 AM |
| Small Block 400ci...or...Big Block 396ci???? | chevyelc81 | Engine | 17 | 10-05-2002 07:06 AM |
