Emissions Removal
I want to take off my Smog pump and plate off the egr along with removing the cat on my 307 olds. Any pointers or heads ups?, aside from the law and environment.
Why do you want to do all that?
Is the cat plugged? what is wrong with the A I R system. What is up with the EGR?
Fact is stranger than Fiction |
It works as it should, but itm going to go with headers w/ true duals and dont want to put cats and plus i have to deal with all that jumble of a mess under the hood
The cats dont pose much , if any, restriction in the exhaust, provided they arent plugged, or the engine is running too rich, causing excess back pressure. But the single exhaust is restrictive.
Also the A I R does push air into the exhaust stream, causing some extra back pressure, mostly at WOT The EGR does help to lower combustion chamber temps to help keep NOX low, and it helps to stop pre ignition . All that said, with a low compression and 307 CI you wont get a real seat of the pants feel , as far as horsepower gain , from just dual exhaust, but it will sound good . Do you still have the computer control carb and distributor? Those were designed to optimize fuel economy and werent noted for performance. The small bore long stroke of the 307 was for the same reason.
headers are available that are smog pump friendly.The 307 is just a stroker 283,great little engine once you get rid of the factory cam and timing set. Perfect candidate for vortec heads camel bumps and a small 4bbl to go with the headers
its a 84 delta 88, im pretty sure it aint got the computor carb/ dist. And milling the heads is a good thought
I did this once when i was younger back in the 80's me and my cusin took the stuff off his car. I cant tell you how bad it ran after that.
If you take it off make sure you keep the parts. You may need to go back to using it. If your carb is electric carb do not remove that stuff it will run terrible until you replace carb and intake. You can tell if it has the electric carb. It will have a few wires running up to the top of the carb to a black thing with star style screws. If you have that leave it alone or completly replace the system. Block is the same but intake, carb and headers will be needed to make it run right again. But take my advice with a grain of salt since I have not tried this in years. We may have just not getten all the parts replaced right. But sure enough 2 weeks later we had to reinstall the entire system bad part was we had already tosed it in the trash. we had to hunt junk yards to find the right stuff. It was ugly. |
*Noise Level being an engineering term where when testing something like an engine on a dyno making changes from run to run shows that whatever is happening it isn't enough to separate from normal variation you see from run to run with a consistent configuration. Bogie |
John L |
![]() John L |
I'd leave it all on.. true duals.. why.. it's a 140hp 307 the egr, doesn't hurt anything, and doesn't function at wot the air system is to help burn the raw hydrocarbons in the exhaust.. hurts nothing.. takes 1/2 hp to turn the smog pump.. I have a 86 SS so I feel your pain.. on the crap under the hood.. but . even if they don't test the emmissions , removal of the parts is a 2500.oo fine each.. my bet is, because they want most older cars retired.. these fines will come to light.. and fix it.. tickets will become the norm. down the line.. if nothing else. save the parts you pull.. you'll gain more from a cam change to the later 307 h/o 185hp factory roller cam. than the duals.. |
| emissions | monster mouse | Engine | 1 | 04-15-2010 11:51 PM |
| Trim Clip Removal, and backseat removal? | ROBINGOODTIME | Body - Exterior | 2 | 10-09-2006 08:15 PM |
| Emissions removal | bigwheel15 | Hotrodding Basics | 19 | 06-22-2006 05:12 PM |
| emissions | EastCoastSBC | Engine | 9 | 12-24-2005 08:44 PM |
| Emissions | 82vettemike | Engine | 10 | 01-08-2003 03:12 PM |
