Empire State Building thought to cause "automotive Bermuda Triangle"
Saw this NY Daily News piece on BoingBoing. They're reporting that cars are mysteriously stalling in a 5-block radius around the Empire State Building.
HomemadeTools.net -- Thousands of Homemade Tools |
That sure is something!!!!
Good find there Jon. |
I wonder if its just computerized vehicles stalling
Shane |
I know there was a plane in the 40s that didn't think much of that building,,,,,,,,,,,,,,,,,,,,,,,,,,,
![]() The picture shows more of a Manhatten Circle than a triangle..........but mysterious none the less.
Ontario Rodders |
Interesting.
'Ber-motor Triangle'
Taxi radios set off the car alarms around my way - could be something similar. Or maybe the aliens are already here...
It's the towing company jamming all the stuff. Really tows off business....
In a while, Chet. |
Who ya gonna call....... Ghostbusters.
Isn't it a little early for April fools day? Later, Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
I totally believe it's plausible, no voo doo required. I installed a remote start on my wifes Focus. There is an electromagnetic coil (or some kind of gadget) ring around the ignition switch. When the key is inserted into the ignition, the coil ring induces current into the chip in the key so it will give off a signal back thats picked up by the ring. If it gets no signal or the wrong signal, it won't start. The remote start required a little transmitter you place next to the ignition switch. You program it to the key frequency so that the key doesn't need to be in to start. I could see some kind of EM field messing that up no problem. Thats probably why you can drive by the ESB and have no problem, but when you stop and try to restart, it can't get a clean signal and won't start.
| Recent Hotrodders' Lounge posts with photos |
