Em's first Ford Hot Rod - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 04-05-2013, 02:47 PM
wretched ratchet's Avatar
one full turn after it squeeks
Maybe it just isn't thick enough Em. Try an old piece of tire.
John L.
Good Idea but I'll have to cut up the spare on the Yota but that would be right in line with the program that the previous owner has put in motion
  #17 (permalink)
Old 04-05-2013, 02:49 PM
Must have been a farmer. A farmer can fix anything temporarily without a trip to town.
  #18 (permalink)
Old 04-05-2013, 05:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Heck Em, if it turns out to much for ya ship that bad boy down here to me looks like a fine toy.
Cole
  #19 (permalink)
Old 04-05-2013, 06:31 PM
Hey Friend, sure good to see you posting here
Cole, I'm finally starting to have fun with it, even tho there's a lot to straighten up. Found out that there was an easy fix for the drain plug if it happens to be stripped out and I've almost figured out how to fabricate some hardware so that the manual choke works (without the pull ties and bailing wire)
How's that Grandbaby doin'? Have you spoiled her stinky rotten yet? Don't lie I know you have.
  #20 (permalink)
Old 04-05-2013, 07:27 PM
My '72 F100 I bought from a rancher had nails holding the hubs in, and a few other things held by them.
Love the Fairlane OP. What size is the motor?
  #21 (permalink)
Old 04-05-2013, 07:38 PM
It's a 289 with a "very" mild cam and a cheap Autolite 2 bbl. I'm really starting to consider putting a double pumper on it. I just don't know "anything" about Ford engines and I don't want to change the intake either so I'll probably run the 2bbl for a while at least.
  #22 (permalink)
Old 04-05-2013, 08:14 PM
Nothing wrong with the Autolite; it's one of the simplest carbs to rebuild. I rebuilt mine having never touched a carb before. They're desired by some off-road guys because they can handle being off-camber without fuel starving.
The pitfall with the 289/302 (from what I read on 'Stang forums) is that alot of guys over cam and over carb them.
  #23 (permalink)
Old 04-05-2013, 08:30 PM
Thanks, like I said above, I know nothing and it's all new to me. I found a brand new Autolite 2100 with a heat choke for $160. It should bolt right up and all I would have to get would be a heat tube. I think I've found the manifold heat source but I'm not sure????
  #24 (permalink)
Old 04-05-2013, 08:49 PM
Never priced them, but the rebuild kits are cheap and simple so buying a new one is a bit of a waste unless the housing on yours is cracked. Here's the guide I used to do it:
http://www.therangerstation.com/tech..._2150_carb.pdf
The heat choke connects to two lines that run into the block under a small panel in the intake on the passenger side of the carb. Those heat tubes feed into the choke on the passenger side of the carb.
You should be able to find replacement heat lines off any sbf in the local U-Pull-It; worse-case you could pull one to use as a template to bend your own.
  #25 (permalink)
Old 04-06-2013, 05:44 AM
That will help me a lot, thanks
So the choke gets it's heat from the intake and not the exhaust manifold? hmmmmmm????
  #26 (permalink)
Old 04-06-2013, 10:52 AM
35terraplane's Avatar
Em that's because you are taking in heat, not getting rid of it.LOL
Bob
  #27 (permalink)
Old 04-06-2013, 11:03 AM
Bobaloo, I'm danged sure hot now after taking 20 minutes to finally get it cranked and when I went to adjust the idle - - - ?guess? what? it can't be adjusted after "they" welded a piece and pull tied it to the throttle rod.
Replacing the carb is becoming more evident to me every day. Now to decide which carb???????
Vote in the October 2012 hot rod art contest: Hot Rod Halloween Jon Hot Rod Art 0 10-25-2012 01:56 AM
February 2012 Hot Rod Art Contest: Non-Woody Hot Rod Station Wagons Jon Hot Rod Art 41 02-27-2012 05:06 AM
hot rod ford bluthar Introduce Yourself 2 10-18-2010 05:30 PM
48 ford hot rod ford hollywood Hotrodding Basics 12 10-27-2009 03:10 PM
31 ford hot rod WilderRods Engine 5 02-02-2005 06:15 PM
