enamel, lacquer,urethane??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2003, 10:24 PM
nova33's Avatar
Ive heard from several jobbers around twn that since Im a newbie I ought to go with lacquer because its easier to repairflaws and more forgiving then the others. Any suggestions???
Old 06-11-2003, 11:22 PM
outlaw17's Avatar
Laquer is for painting cars that Fred Flintstone would drive , you need to look into Basecoat /Clearcoat , its waaaay easier to use (in my opinion) and easy to fix flaws , its more money but its a much better product .
***** GO OILERS GO *****
Old 06-12-2003, 12:18 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I wouldn't consider using anything but catalyzed urethane. Easy to use, extremely durable, polishes great, and most importantly, in California, lacquer is illegal.
Old 06-12-2003, 07:37 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Laquer is easy, but not as durable.
Most young painters have never painted topcoat laquer.
If your painting an everyday beater, I would use acrylic enamel,
it can be sanded smooth.
On a classic,hotrod, showcar etc. I would use a BC_CC sys.
Ofcourse with BC_CC you have twice the chance to get trash and runs and saggggs.
You might check with dupont, they used to have a sys. called 502
used a laquer base and enamel clear. and was easy to work with.
Good Luck;
Troy;
69s Forever
Old 06-12-2003, 09:15 PM
adtkart@aol.com
I used to use Laquer all of the time. Can't even get it here anymore. After going to BC/CC, wouldn't even want to try.
Old 06-12-2003, 10:33 PM
troy-curt's Avatar
I have used a lot of laquer, very easy to apply, hard to sand, polishes beautifully,will not stand the elements.
Some of the top show cars in the world are painted with laquer.
It`s not as hard on you to breath. But i`ll stick with BC-CC. ALSO
TROY CURTSINGER;
Old 06-12-2003, 11:22 PM
Mirror Image's Avatar
Im with all the other guys go with the urethane basecoat-clearcoat such as PPG or Dupont and be sure to use urethane primer as well
Old 06-13-2003, 08:33 PM
adtkart@aol.com
If you really want to enjoy the painting, use laquer and cut down on the ventilation. Just be prepared for a dilly of a hangover in the morning.
