Enamel, Laquer and clearcoats - how to prep? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2009, 08:32 AM
I am painting over my motorbike using panther pink and black for striping. So far I have painted most of the bike over flat black...however I have noticed that while most of my paint i used was a acrylic laquer...the latest can i bought (since there was none of the other kind)..is enamel.
I am painting the bike all over black, then stripe it, and paint with pink. My question is, since I want the black to be "flat" for now...can I sand both the laquer and the enamel (after a few days of drying time of course) - with 1500 grit sandpaper? Then tape it up for my pink?
I know you can put enamel over laquer, so I solved a bo-boo I was about to make today with that issue...but here's my next question:
If i can sand both blacks, and I apply my enamel pink paint...I want to apply a clearcoat over all of it once its done...what should I do at this point?
Basically given this is what i have to work with...what should be my steps?
Old 05-21-2009, 11:20 AM
Last journal entry: 50 Ply wagon
The problem you will have is the clear. If you use a regular clear, the flat black will be shiny. To have it look like flat ,you have to use a flat clear, so everything will be flat looking.
Old 05-21-2009, 11:25 AM
Ok, so beyond that there should be no problem? That's ok by me.
I am wondering tho. I sand the black with 1500 all the way over, THEN do the stripes with tape...
Paint with pink, take off tape...
My question is right here at this point: Do i sand my acrylic enamel pink coat with 1500 as well before I clear the entire thing? or not?
Old 05-21-2009, 03:45 PM
yes, sand wet with 1500 lightly.
Old 05-23-2009, 03:21 PM
Ok, I picked up some 2000 grit sandpaper as well...just in case
Now, after i have my colours sanded and a coat of clear on to it, i sand it down with 2000 grit sandpaper for a 2nd coat..
should i sand it after this then buff/polish it? Or should i just leave it be?
Also if a rubbing compound is recomended what do you recomend? I bought some turtle wax rubbing compound..but I dont like what I read about it. The clear will be acrylic enamel clear...
