Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $3,440.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 09-07-2006, 09:55 AM
cutsupreme cutsupreme is offline
Enamel Paint and clear
I have been having some problems painting my caprice and am hoping that you guys can help.
The paint I got was an enamel Burgandy metalic
Everything was going fine up until I put on clear coat. It came out all orange peel and wasnt all that shiny. The clear I used was also enamel. So I tried just wet sanding one fender and re shooting the clear. This time it came out nearly perfect but with a couple fisheyes. So then I decided to wet sand the whole car and try it.
So I did all the wetsanding and reshot the clear. The car came out looking almost as bad as it did the first time.
Then someone told me that I couldnt use clear over enamel paint...is this true??
i heard that enamel paint takes a long time to cure. so do u think this is my problem
Thanks for any help
Old 09-07-2006, 10:26 AM
milo's Avatar
milo milo is offline
keeping it a hobby
Your gonna have to tell what brand / company / what it says on the can etc...
Old 09-07-2006, 11:07 AM
Old 09-07-2006, 11:22 AM
milo's Avatar
keeping it a hobby
What happens when you call the phone number?
Old 09-07-2006, 11:26 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Streetbeasts lawsuit donor
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
Fisheyes are caused by some sort of contamination either in the paint..oil in sth air line or something left from cleaning the surface..Guys even get fisheyes from sweat getting on the car..
Orange peel is a gun adjustment..when changing products from primer to base coat to clear one needs to do a sprayout to see that the gun is adjusted to spray that product well..
I have never used any of what you are using so cannot comment on that..
Sam
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 09-07-2006, 11:45 AM
is it true though that you cant spray clear over enamel paint???
Old 09-07-2006, 12:12 PM
jcclark jcclark is offline
The Penny Pincher
Yes, (you're talking about clear urethane, right?)
it's recommended to wait 24 hrs to use urethane over enamel.
I would stay with the enamel clear myself.
Old 09-07-2006, 12:38 PM
BarryK BarryK is offline
NO it is not true.
You can spray urethane clear over alkyd enamel or acrylic enamel but the requirement is you must activate the enamel and let set 4 hours or overnight for best results and then clear.
Sounds like your problems may be coming from not activating the enamel??
The fish-eyes are most likely advanced solvent pop or gassing.
Old 09-07-2006, 12:39 PM
Does it matter with the enamel clear I'm using??
Old 09-07-2006, 12:53 PM
[QUOTE=cutsupreme]Does it matter with the enamel clear I'm using??
If the clear must be activated, then yes.
If the clear is not an activated clear then no.
Old 09-07-2006, 01:11 PM
I used
4 parts clear
1 part reducer
1 part hardener
Old 09-07-2006, 01:12 PM
wisch79 wisch79 is offline
What would be the advantage of spraying say a urethane clear over acrylic enamel? Also by activating it you mean adding a hardner right? Sorry for butting in but I am just curious.
Old 09-07-2006, 02:18 PM
Ist I'm not sure anyone even makes an enamel clear anymore but if they do you would have a choice of whether to activate or not.
The advantage to using a urethane is it will have better gloss, last longer and be much more durable.
Old 09-07-2006, 05:06 PM
kenseth17 kenseth17 is offline
An enamel cures air dry, but would be a long long time till it cures all the way through. Probably many many years from what I understand. It can be activated to make it more like a urethane. Urethanes must be activated and they cure chemically by crosslinking (adding a hardener). The flash times and cure times and time to clearcoat window are much longer with an enamel, at least a single stage system as opposed to a converted enamel basecoat, I've seen a week time to clearcoat, really don't pay much attention to tech sheets for enamel anymore. I suspect barry is on the money. That enamel probably hasn't cured enough and solvents are building up or have not gassed and then your getting solvent pop in the clear. I would activate the enamel and extend your time to clear. I am not aware of enamel automotive clear, but if there was I think I would pass and use a urethane. With the problems, repainting, and the extra wait time, how much of a bargain is using that ebay paint over a base/clear system, if you were planning on clearing anyways. Some lines of urethane singlestage aren't too steep on price.
Its not true you can't clear over enamel paint. Many painters for years would spray the last coat of single stage with clear mixed in. And if you plan on buffing metallic you need a clear on top to do so. Many of the cheaper basecoats are a converted enamel which has to be cleared.
Old 09-08-2006, 06:25 AM
I went to my local Napa auto parts store yesterday and they recommended using Transtar Urethane Clear. It cost about $90 for the high gloss stuff, plus the price of the activator.
Does this seem like a good option?
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Enamel Paint and clear"
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 24 10-22-2007 11:20 AM
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 23 01-28-2006 01:18 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 08:08 PM
OMNI signal stage paint with Clear?? scheetz93 Body - Exterior 8 08-04-2004 11:36 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
