enamel reducer in urethane by accident - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2010, 11:07 PM
mike, 70 ss el camino
I accidentally mixed some Omni (MBC) urethane basecoat with acrylic enamel reducer instead of urethane reducer. Applied one coat and stopped. It seemed to work OK. I'm painting a gas door and some small parts so it's not a real big deal but I hate to throw away a a pint of paint if I don't have to.
I know urethane reducer will work in acrylic enamel. I do that regularly when I paint chassis parts and never have a problem but I always heard that you should never mix acrylic enamel reducer in urethane paint.
Thanks for the help.
Old 10-15-2010, 03:43 AM
You will be fine at one coat, do your self a big favor and let that one coat set 24 hours before applying additional base.
Old 10-15-2010, 10:07 PM
I did not read our post in time and ended up waiting about 12 hours before reshooting. The biggest part was the underside of the hood. I resprayed with the correct urethane reducer and new paint/clear and it all worked out fine.
Thanks very much for the reply.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 06:58 PM
Urethane Clearcoat Reducer DGW Body - Exterior 47 11-15-2007 09:13 AM
Clear urethane over acrylic enamel? Kawdennis Body - Exterior 3 05-07-2007 02:46 PM
acrylic enamel vrs urethane americanLT1 Body - Exterior 4 09-15-2005 10:23 AM
