Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Enamel vs Urethane vs Polyurethane????
Old 07-23-2004, 05:00 AM
BarryK BarryK is offline
Originally posted by MARTINSR
OK, you have cleared up a lot on the linking, if I am understanding what you are saying that is. Tell me if I am wrong.
A polyurethane has "many" resins, thus many different molecules to link, right? I see a urethane as let's say black and white marbles covering the floor with strings going from one to another. Then polyurethane as black, white, red and blue marbles covering the floor with strings going from every white one to every other color and every red one to every other color and so on. Am I on the right track?
I have herd this taught this way before. It works, I just like the ladder.
OK, if I am on the right track that is great. But now with the confusion. You say that a urethane would have a 4:1 mixing ratio with hardener and a polyurethane would have a 2:1, 3:1 or 1:1 ratio, or do you mean the ratio with ISO molecules?
The NOCS are matched in each product so you can have a quart of activator for a product be it any ratio, and one quart may be 33% Iso's in that quart can, the next system may be 75% iSO'S.
Because if you mean with hardener, S-W acrylic urethanes use a 3:1 ratio. And by the way, you mentioned PPG "Concept" SS in that other thread implying it was a polyurethane. But it is advertised as a acrylic urethane, not a poly.
It is an acrylic, I was referring to the clear and Primer as far as the poly's.
Ok, next question, I mentioned this in the first post. Many of these products like IMRON and S-W Genisis and PPG Delta have dedicated mixing banks. The toners and hardeners are not used with any other system. This makes sense, as far as the name it is called actually being believable. Genisis is called a "true" acrylic urethane while IMRON as I remember is a polyurethane and Delta, I don't remember, I think it is just referred to as a "urethane". Anyway, ok, they have a dedicated system.
What about something like Chromaone, Concept, or TecONE they are mixed off a mixing bank which also provides the base coats, interior colors, (with S-W a number of different urethane SS) and even acrylic enamel on some of them. All these systems use ALL the same toners for all the "qualities". All of these systems are basically, acrylic enamel systems! Yet with a different mixing clear or "drier" or something they magically become an "Acrylic urethane"?
How?
All of them start out as Polyester (lacquer) or Enamel. and than taken from there as far as if blender is in the tints or added later,
THATS where the magic is in the blender of course if its mixed with the tints to start with your more limited. One of the most unique systems was the UTech system. You may have seen it system was pure tint. so off one system you could make laquer or polyurethane!!
