Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Enamel vs Urethane vs Polyurethane????
Old 09-01-2005, 01:36 AM
n66ht's Avatar
n66ht n66ht is offline
New Member
So you can add resins with the "mixing clear" to the toners in the formula and make a true polyurethane because you are simply adding different resin making it "poly"?
I remember using SW U7000 system and when we had to touch up a chip etc. I would mix up the color in a small cup with the single stage mixing clear(binder) in stead of b/c mixing clear. Add urethane reducer in stead of b/c stabilizer, a drop of smoothie a drop of urethane hardener and touched up. The paint would come out glossy not flat looking like b/c and it would harden up and stick like s/s.
