Endura EX-2C as Frame paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2005, 01:50 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi,
Someone has suggested that I use Endura EX-2C Black (#160) on my freshly sandblasted frame. They say that it is "tough as nails".
My question is: Can I apply it directly or would it have to be primed first with Endura primer? (EP-FD)
Old 08-08-2005, 01:58 PM
BarryK's Avatar
I surly would not be taking anyones opinion on this! This kind of redo requires body-off and a lot of work.
I would get tech sheet from company or call company and get from horses mouth instead of horses --well you know the rest of the story.
Old 08-08-2005, 02:32 PM
66GMC's Avatar
Tech Sheets
Hi Barry,
Thanks for the advice ... that's exactly what I did.
http://www.endura.ca/adobe/topcoats/ex2ctopcoat.pdf
The EX-2C is a polyurethane industrial top coating with a "pencil-hardness" of 2H which they say withstands abrasion very well.
As I suspected, it DOES require an epoxy primer, which needs to be sanded before applying the top-coat.
http://www.endura.ca/adobe/epfdepoxyprimer.pdf
I was hoping for a durable "one-shot" coating ... any suggestions?
There is also a place nearby that does powder coating, but I know very little about the cost or durability. Any comments on that idea?
Old 08-08-2005, 03:47 PM
BarryK's Avatar
Looks like a good epoxy and I understand it to have a 7 day open coat.
In short above 60 degrees you can spray the polyurethane over it without sanding the epoxy for 7 days.
I would spray the epoxy and let set at least overnight if not two nights, than no other prep is necessary just spray your single stage.
Note the epoxy has a 30 minute induction time:
That means activate it one part to one part, mix and let set AT LEAST 30 minutes, then mix with stick again and spray.
2H hardness is typical of a polyurethane and an excellent standard.
Old 08-08-2005, 06:17 PM
66GMC's Avatar
Thanks
Thanks Barry.
Although this is gonna be (relatively) expensive ...
Epoxy Primer:
1 qt EPFD-A $45.00
1 qt EPFD-B $47.00
Black paint:
1 qt #160-A $32.25
1 qt EX2C-B $32.25
3M 07178 respirator mask $51.00
(hopefully it will keep the isocyanides from killing me)
It's what I'm going to do. It should look fairly "pro", and as you said, it's a huge "re-do" otherwise.
I just keep telling myself "I'm saving a ton on labor"
Another upside to this is that I'm pretty fussy, so I'll have no-one to blame but myself if this truck doesn't turn out the way I want it!
If the weather is good I may shoot the frame this weekend. Wish me luck and watch my project journal for progress.
I think that I'll give the bottom side of the cab the same treatment when I get that far.
Don
Old 08-08-2005, 07:13 PM
BarryK's Avatar
Justify it this way!
What ever your body shop labor rate is ($45?). an hour, just tell your wife after you spent 8 hours in the garage how much you saved!
Take your time spraying, don't rush and remember when painting "time is always on your side" (that means don't rush the coats)
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
Frame Prep & Paint MadPower Body - Exterior 6 07-01-2005 02:04 PM
Frame and Chassis Paint Barrybomb Body - Exterior 6 05-03-2005 04:27 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
