Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which Energizer Cam would you Recommend.
Old 03-06-2004, 09:32 AM
FBody FBody is offline
Hi,
I would like to have your advise on which Camshaft to select for my engine:
1) Crane Energizer 266H,
2) Crane Energizer 272H,
3) Or another CAM.
What I'm after is:
1) Good Get Up and Go at the corner of the street.
2) If possible, Performance/Lumpy sound, I wouldn't want the car to be a Dog at low RPM.
My Engine & Car Specifications are follows:
1969 Camaro
TH350 Transmision with a shift kit.
Stock Stall Converter.
3.73 Eaton Posi Rear-End
Rear Tires: BF Goodrich Radial T/A 235/60R15, 26.1 Diameter.
1972 350 Engine (approx. 8.5:1)
Cylinder Heads, Rebuilt GM 333882, 76CC with 1.94 & 1.5 Valves and stock springs.
600 CFM Holley Carburator
Edelbrock Performer Intake Manifold
Dynomax Ceramic Coated Long-Tube Header, 1 5/8 " Primary Tubes, 3" Collectors.
Dual 2" Mufflers.
Does some of have had experiance with the above Energizer Camshafts in similar setup, If so, I would appreciate to hear some of your feedback and recommedation.
Thanks,
Daniel.
