Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which Energizer Cam would you Recommend.
Old 03-06-2004, 10:48 AM
Ghetto Jet's Avatar
Ghetto Jet Ghetto Jet is offline
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I would recommend the Comp Cams Xtreme Energy 262H its a step under the XE268H but is more suited to your application. The XE262H specs are Dur. 262/270 and lift .462"/.469". It has great lowend and makes power up to around 5,700 RPMs. Will work great with your stock converter. You probably have seen a lot of magazines using the Xtreme Engergy 268H cam, but it does require a slightly higher than stock converter and a exhaust system larger than 2". The two Crane Cams you listed won't give you that lope that you want, they are both very tame cams.
