-   -   Eng Hp 1978 350 vete engine (http://www.hotrodders.com/forum/eng-hp-1978-350-vete-engine-31611.html)
Buffed 01-05-2004 02:42 PM
How much HP would I be getting from my 1978 vete 350 chev eng.the bottom end is stock but it has 202 heads straight plug, headers ,650 holly carb ?
rifraf 01-05-2004 02:47 PM
What manifold do you have,what 202s do you have,is the cam still original?
tm454 01-05-2004 06:38 PM
I had that same setup in my 78 Impala station wagon man... It had 178hp.
Tazz
Rat Rods Rule!
mikeweyman 01-05-2004 07:01 PM
i'd have to agree, my 75 in its stock form was a real dog out of the hole, it was 165 h.p.
a 460 lift cam, headers, 2 1/2" exhaust,weiand excellerator intake , holley 680 d.p. msd ignition. it is only 1.95 / 1.6 valves though. the best guess i got for those mods was 325 h.p. max.mike
Pony 01-05-2004 07:49 PM
The highest stock specs were 185 hp for 1978. Emissions killed the HP output on the SBC in the 70's. My 1974 350 Vet only has 8.5:1 CR and that all by it's self limits the amount of HP it can make. Closed chamber heads will boost compression and everything else with help but your still limited.
