eng. swap 454 and t56 6 speed into 1990 1995 chevy half ton short bed truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2010, 03:08 PM
my question is if i use av6 truck how do i change those eng. mounts,Heard they were rivitedin is there aspl. tool,what trans mount do i use,my 6 speed is a1993 camaro with the slave cyl on the side of the trans.will i have problems with this,whah about the drive shaft willi have to modify it.Ihave not purchased the truck yet sa Iam having problems finding a 1990 to 1995 truck with 5spd and v8 eng.I heard the 96 to 2000 trucks gmc and chevy,you can not buy long tube headers for those years.tks. crk1975.
Old 06-13-2010, 07:41 AM
Wiki Edits: 49
Is this question in English??? If so it must be in some obscure dialect from the sticks.
Here's some free advice and feel free to take it or leave it .... Take the time to use proper capitalization, punctuation and some semblance of grammar and you'll find people will be much more likely to answer your questions. Most of us don't have the extra time it takes to decipher someone's less than readable post just to answer a simple question.
Old 06-13-2010, 09:00 AM
powerrodsmike's Avatar
Wiki Edits: 161
As I am an unfinished product of the California school system, with experience at text messaging and several kids worth of "Hooked on Phonics, (and too much time on my hands), I'll give this translation a try..
Mikey's interpretation of crk1975's question in bold:
My question is: If I use a v6 truck how do i change those engine mounts? I heard they were rivited in. Is there a special tool?
What trans mount do I use with my 6 speed, it's a 1993 Camaro with the slave cyl on the side of the trans.
Will I have problems with this swap?
What about the drive shaft will I have to modify it?
I have not purchased the truck yet as I am having problems finding a 1990 to 1995 truck with 5spd and v8 eng.
I understand that you can't buy long tube headers for the 96 to 2000 GM trucks.
thanks,
crk1975
Later, mikey
BE different....ACT normal.
Old 06-14-2010, 05:15 PM
Tks. Miki.
Tks. Miki.
