with the stall you have someone has already done some work i would bet or it would be for nothing check your heads take them off and check them good.the intgake is good but you can go higher if you want to with a carb raiseing block put about a 500 lift solid cam behind it put hardened pushrods in it then check bottom end and see what it has also drop that rear some if you want to come out hard
