Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engin oil pan swap
Old 12-20-2012, 01:22 PM
cdminter59 cdminter59 is offline
Engine oil pan swap
Check out this Moroso oil pan for F-body LS engines. Moroso Street/Strip Oil Pans 20140 - SummitRacing.com I guess you could call Moroso's tech line and ask if it will fit the vehicle you are putting in. I am sure they will probably tell you to take measurements. It is a rear sump oil pan and it will fit the L76 engine just don't know if it will fit what ever you are installing it in. Check out this forum for info. Disable DOD - LS1TECH
