#1
engine
does anybody out there know if an aftermarket cast alum. oil pan will clear the stroke on a 350 chevy running an Eagle 383 stroker kit? Im running a off shore chrome pan now and cant get it to seal at the timing chain cover. Have the pan off 3 times. I think the alum. pan would be better cause it twist. Thanks.
Register now (free) or login to remove ads |
#2
http://store.summitracing.com/partd...15&autoview=sku
It's not aluminum but this is the pan I am running now an I have had no sealing issues. It fits strokes up to 4.125 in. with steel connecting rods. Any stock style pan will probably need to be clearanced to work... |
#3
chrome oil pan
hi,i had the same problem. sand the lip of the pan,where the gasket fits ,with 320 . ion mine the chrome was too slick to hold the gasket and the gasket would walk out. this MIGHT be your problem. then use hi temp sealer on the gasket.
| Thread Tools | Search this Thread |
| Similar Threads for: "engine" | ||||
| the history of chevy v8's | savman1 | Engine | 32 | 08-11-2010 12:30 PM |
| 1973 Chevelle Malibu Engine Rebuild (pics 56k no) | Malibu73 | Hotrodders' Lounge | 39 | 11-04-2008 01:37 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 11:22 AM |
| Why high RPM's on the oval tack? | steveyb4342 | Engine | 25 | 05-23-2007 08:50 AM |
| question for any engine builders out there | mopar72 | Engine | 7 | 11-06-2005 04:06 PM |
