Go for it great potential.
Check out this link. http://www.cars-on-line.com/48olds12398.html I would go for an olds 455, not much heavier than SBC an tons of torque stock close to 500ft/lbs. No boat anchor there. Joe |
Realistically would this size of a motor be worth the gas it would probably guzzle.
I would like something that I could use as a daily driver. Also What kind of Transmissions would I be able to mate with this motor. I was thinking of something with overdrive to save on the gas going down the highway. Thanks Eric |
Daily driver...go Chevy 350/350 turbo........Sorry, all you Old's lovers..
Ontario Rodders |
I'm no Olds expert but I believe you could hook up a modern 700R trans with overdrive to the 455 with no trouble at all. Although the 350/350 combo would be reliable for a street cruiser, it would also be just another "cookie cutter" street rod. The SBC has been done to death, that's why people yawn when they look in the engine compartment of most street rods. Centerline |
YAWN.........................zzzzzzzzzzzzzzzzzzzzz zzzzzz
But dependable as heck.....................
Ontario Rodders |
Centerline said: Your gas mileage will be directly related to how heavy your foot is.
Now I know he was kidding on that one. But now wouldn't even at idle the larger engine burn more gas. And how much? I would like the large motor for the sound and one of a kindness. But, I am trying to think practical. Any input I can get would be helpful. Also where is a good place to start looking for motors and transmissions. Online around town? Sorry if this seems like a dumb question I just have no clue where to begin when it comes to finding an Engine. Thanks Again for the replies Eric |
Things to consider when choosing a power plant: What type of driving do you plan to do. Mostly around town? A trip to the track on weekends? Highway cruiser? Also how many miles do you plan on driving it? If you plan on a lot of long distance trips or putting a lot of miles on the car each year then maybe a small block would be the best choice. If you're not going to drive the car more than 5000 miles a year than the extra "fun" factor of the big block would make sense. Especially when you cruise the local shows on the weekends. As I've said before, I'm an advocate of being a bit original when it comes to building a rod. Sure the small block Chevy is reliable but so are most of the other V8's out there. It's been my experience that people choose the SBC simply because parts are cheap and plentiful. What they fail to realize is that for some of the more original motors, parts aren't hard to find either. You can pick up anything for a 455 you're going to need on a routine basis at any local parts store, just like the SBC. Then, of course you have the exotics like Hemis, the 348/409's, Buick Nailheads, and Flathead Fords. These engines, although reliable will cost an order of magnitude more to rebuild and keep running than a SBC. People choose them for one of two reasons. Either because of their horsepower potential or the "wow" factor. Personally I'd rather have someone peek into my engine compartment and go, "wow, look at that", rather than just glance in and then move on. It doesn't take a lot go get that reaction, but unless you've got deep pockets and can afford some exotic induction system and a lot of chrome, you'll never get that with a SBC. Now that I've made my case, figure out what you want to do with the car and how you're going to drive it and go with what you believe is the engine that will meet you're requirements. And by all means and most importantly, have fun. Centerline |
I appreciate the insite and the lengthy reply Centerline.
I will mostly be driving this car around town. But I don't want it for dragging or racing. Just to tool around and maybe occasionally go on a short little road trip now and then. I have also be considering the fact that I would like something that is one of a kind and something that would go along with the car. An olds for and olds. I guess I am going to go for the 455. Would someone be able to give me some information on these engines. Also I have begun to wonder what sort of Transmission would be recommended a manual or Automatic or does it really matter. One more question that is all will this engine in stock form give me that rummble that I would like to have. So everyone would no I pulled up when I arrive at there house. Or does that require something extra. thanks again Eric |
To begin with you really don't have to go all the way to the 455 to get a unique Oldsmobile big block in there. There are several factory high performance big blocks that preceded it that would be excellent choices if you don't want or need the big torque numbers the 455 offers. Here is a link to a Olds 442 history page which gives a quick outline of all the factory high performance big blocks Olds offered from '64-'73 from the small block 330 (not recommended) all the way to the 455. The 455 was just the last version. The factory offered some over the counter goodies to spruce up these engines and I'm sure if you do a search on the web you'll find places that still offer the same cam grinds that were available as an option from Olds back then. Even with the stock factory high performance cam it will sound pretty good and if you replace it with one of the factory optional grinds even better plus it will still be drivable.
If it were me based on what you've said you want to do with the car, I'd go with the TH-350 or 400 trans and a 3.50 or 3.23 geared rear end for a nice cruiser. Although you could just as easily bolt up a 4 speed. I'm not sure if any of the late model 5 or 6 speeds will work though. Also, I'm no expert on GM transmissions but the 700R4 may bolt up also. Happy shopping. Centerline Last edited by Centerline; 03-31-2004 at 06:32 AM. |
