engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 07:48 PM
Post engine
i started my truck but it died started it again and it died again after about 30 seconds of running can anyone give info on some thing to try to trouble shoot on thanks
Old 12-10-2002, 07:51 PM
BOBCRMAN@aol.com's Avatar
Post
if you're in michigan right now you have a frozen gas line.
Old 12-10-2002, 08:46 PM
xtreme off-road's Avatar
Post
Check your fuel pump fuse(s). Some vehicules have 2 circuits for the fuel pump. When you initially turn on the key, the computer primes the fuel system and will give you enough fuel for about 30 seconds. Then once the engine is started, the oil pressure switch fires a relay that keeps the fuel pump running. <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 12-11-2002, 01:41 PM
Post
[quote]Originally posted by xtreme off-road:
<strong>Check your fuel pump fuse(s). Some vehicules have 2 circuits for the fuel pump. When you initially turn on the key, the computer primes the fuel system and will give you enough fuel for about 30 seconds. Then once the engine is started, the oil pressure switch fires a relay that keeps the fuel pump running. <img src="graemlins/pain.gif" border="0" alt="[pain]" /> </strong><hr></blockquote>
I HAD A SIMILAR PROBLEM WITH 97 350 CHEVY VORTEC.
THE FUEL GAGE FLUXUATED AND BY TROUBLE SHOOTING
I FOUND THE FUEL SENDING HAD SHORTED OUT.
[ December 11, 2002: Message edited by: jim rogers ]</p>
