Typically.
There are 2 sets of holes in the suspension cross member for engine mounting V~6 & V~8 . Did the car have a V~6? If so I would look to see if the Motor mount was not put in the wrong hole. If it is that far off with a upgrade in power there is going to be busted stuff . You need to find WHY there is a mis alignment & only then can you fix what is wrong. It is possible like you said that the frame is bent . I would start with a basic measurement test. Measure from center point of wheels on the left them the right . Then get under the car & do a "X" measurement , from side to side front to back in the same spot on each side measure all these should be the same if they are not ..you have problems. R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Thanks for the reply Rob!
I figured someone on this site had swapped motor mounts in a Monte? If memory serves, I did the "X" measurements 20yrs ago and it was close. I'll do it again to be sure. I bought the car secondhand in '89 with a 305. Being that it was an SS I didn't think they cam with a V6. I could be wrong. I guess I'm going to have to drop the control arms to get inside the frame to see if I can loosen/replace the motor mounts. I have a new set of motor mounts for a '75 Camaro. Any idea if they are the same? Thanks again, ssmonty |
No Problem.
You can do the "X" in lots of different spots . It will go faster if you have 2 people .One on the smart end & one on the dumb end. I am 99% sure that Motor mounts are universal ,bolting them up is a BIG PITA. If I remember right a Ball swivel socket is a life saver in this job. Also some good magnets , to retrieve the nuts & bolts . Here's a couple of trix. . . If you take some paper & put it over the bolt then stick it in the socket it will hold it in places & still let you get your socket back. If your swivel socket is loose a little electrical tape will hold it from flopping around. It most likely easiest to drop the bolt down thru & nut it from underneath. this way there are no clearance issues with the "cup " on the Motor side of the mount. Please let me know what you find out on the misalignment part. Good Luck R
Bogie |
Since it drives good...no vibrations or anything...you could just drill some new holes in the trans crossmember to line up your trans mount.
Thanks for the input all of you!!!
You gave me a couple of things to think about! I'm trying to figure out how/where to put jack stands with the control arms out so that I can tighten the mount bolts after I get the engine and trans in. Its gonna be fun! Its gonna be a while before I get my 383 together and swap engines, but I'll post with pics when I do. I'm sure I'll have more questions before then. I'm taking my time and triple checking everything I can. Thanks again! ssmonty |
Mounts
I gave up on undoing the brackets on the frame and cut the heads off the bolts off with a grinder . I am changing from a 4.3 to a 350 in a 1989 pickup. I had to move the female part of the mount 4.5" ahead but the bracket stays where it was. I welded them on the bench. When the 350 goes in I will line up the holes and weld the bracket to the frame . Good welds for sure.
Clint |
Have you tried bending a wrench to make it get on the hidden bolt heads? I've heard you can get on them with a creative combination of socket accessories or a properly bent wrench. Haven't had the opportunity for a first-hand experience yet, so I can't say for sure.
| crate chevy 302? | Vancouver Grand Prix | Hotrodders' Lounge | 106 | 12-31-2012 04:05 PM |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 11:33 AM |
