Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine alignment
Old 07-22-2008, 09:42 AM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
No Problem.
You can do the "X" in lots of different spots .
It will go faster if you have 2 people .One on the smart end & one on the dumb end.
I am 99% sure that Motor mounts are universal ,bolting them up is a BIG PITA.
If I remember right a Ball swivel socket is a life saver in this job.
Also some good magnets , to retrieve the nuts & bolts .
Here's a couple of trix. . .
If you take some paper & put it over the bolt then stick it in the socket it will hold it in places & still let you get your socket back.
If your swivel socket is loose a little electrical tape will hold it from flopping around.
It most likely easiest to drop the bolt down thru & nut it from underneath. this way there are no clearance issues with the "cup " on the Motor side of the mount.
Please let me know what you find out on the misalignment part.
Good Luck
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
