Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Alive. But Idles to High
Old 07-09-2002, 06:34 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
My old Quadrajet had a problem w/ the secondaries sticking open.Check on the butterfly shaft for the secondarys on the passenger side theres a little lock there that allwas used to be a problem on mine.
Also when you put the carb on did you hold the butterflys open to make sure they cleared the intake.Some times they'll stick.
