Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine angle
Thread: engine angle
Old 05-02-2013, 06:08 PM
sedanbob's Avatar
sedanbob sedanbob is offline
Ideally, this should be calculated with the vehicle at ride height, front and rear. Since you mentioned you will be changing the rear differential, if you plan to change the height of the rear suspension, try to have the rear of the car where you intend it will be after your changes.
