engine angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2013, 02:04 PM
engine angle
HI my name is Craig, I have a 1952 f1 that I am installing a 351 w in I have the engine and transmission sitting in there with aftermarket crossmembers looks good, how do I figure out the angle or what does the angle need to be at, I will be installing a new differential too. can anyone help me?
Old 05-02-2013, 02:44 PM
You need to get the carb level, if using one. That means mocking up the installation with the intake your going to use and leveling the carb pad front to rear and left to right.
Bogie
Old 05-02-2013, 07:08 PM
sedanbob's Avatar
Ideally, this should be calculated with the vehicle at ride height, front and rear. Since you mentioned you will be changing the rear differential, if you plan to change the height of the rear suspension, try to have the rear of the car where you intend it will be after your changes.
Old 05-02-2013, 07:21 PM
techinspector1's Avatar
Wiki Edits: 326
The motor/trans unit can be positioned anywhere in the engine bay to miss other components such as steering, brake booster, etc. You have to keep the centerline of the crankshaft perpendicular to the centerline of the rear differential, but other than that, the package can go most anywhere you want it to. '60's/'70's Mopars sometimes had the package as far as 3" to the passenger side to clear other components such as valve cover to brake booster clearance, so don't think it has to go right down the middle. It doesn't, as long as there is breathing room for the bellhousing and transmission in the driveshaft tunnel. And even that isn't sacred. You can cut some sheetmetal out to make the whole mess work if you need to, then weld it back in after the swap is complete. Just leave enough clearance between any part of the motor/trans and any sheetmetal to prevent contact and subsequent noise in the passenger compartment. The motor/trans must be segregated from the sheetmetal of the truck by rubber or urethane mounts at all locations. Rubber is better in my opinion, not so harsh.
One more thing, good engineering practice dictates running the exhaust out to the rear bumper. Terminating it under the truck will create a droning in the truck sheetmetal that will make you crazy in short order. Install an "X" or "H" balance pipe before the mufflers for a more pleasing tone and slightly better performance/mileage.
Excessive engine angle? Grogetter Engine 4 02-09-2011 06:12 PM
engine mounting angle? mike bryan Engine 3 11-12-2004 06:19 PM
engine angle beetle9 Transmission - Rearend 4 04-22-2003 09:13 AM
Engine angle?? Bluepen Engine 5 03-02-2003 01:01 PM
engine setup angle carolinakid Engine 2 01-11-2003 09:24 AM
