Engine angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2013, 08:25 PM
Engine angle
I am working on a 74' Vega, tube frame, body is set at 2.5 degrees postivie, frame is at 1 degree positive. How many degrees at angle should the motor be set at? Thanks!
Old 09-15-2013, 08:32 PM
techinspector1's Avatar
Wiki Edits: 326
It only matters if the motor is carbureted. If so, the carb pad on the intake manifold should be level with the ground. That is not to say that a builder could not cut the carb pad for parallel with the crank and install the motor level with the ground, particularly on a dedicated race car like this sounds to be.
Old 09-15-2013, 10:02 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I agree with tech.
I was taught to locate the crank at the frame c/l and to level the manifold on a carbureted motor.
Old 09-15-2013, 10:05 PM
life is a temporary assignment
I agree with both,, I do the same..
Old 09-16-2013, 09:36 AM
if you beat my boat, well race
i believe i can throw my .02 in here.
i have always set my engines to " zero bubble" on the intake carb flange.
since ive been building boats, ive found that getting the carb level under hard accelleration is the way to go.
im thinking that this is also applicable to cars.
Old 09-16-2013, 09:25 PM
Thanks everyone getting back to me so quickly. Now I know exactly what to do!
Old 09-18-2013, 04:37 PM
kso's Avatar
kso kso is offline
One more comment...however the carb sits or if it has f.i. etc., another consideration is coolant...you need the engine up at the front a little, since the crossover passage and outlet on the intake is there, to help keep air from being trapped in the cylinder heads.
engine angle f1 crazy Engine 3 05-02-2013 07:21 PM
Question on engine angle Stroker56 Engine 11 05-11-2005 12:34 AM
engine angle beetle9 Transmission - Rearend 4 04-22-2003 09:13 AM
Engine angle?? Bluepen Engine 5 03-02-2003 01:01 PM
engine setup angle carolinakid Engine 2 01-11-2003 09:24 AM
