Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Assembly Lube of choice?
Old 05-18-2012, 09:14 AM
AutoGear AutoGear is offline
When I was in school; the goo of choice was Lubriplate 105. Is this still the case? A lot of old farmers just used 30wt oil as long as you were going to run it ASAP. Ive also used petroleum jelly here at the shop to put gearboxes together (thick enough, dissipates easily in oil and cheap, however it does get really thin when its hot out). I just don't want to buy 37 different bottles to put together 1 shade tree 307
