engine backfire! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2011, 12:59 PM
engine backfire!
Hi, I ran my car down the strip a couple of times this summer,my chevy small block is mounted up to a T5 manual box. What I did notice when I went through the gears I had a loud backfire through the exhaust when i stuck the clutch in to get another gear,is this a leaning out symptom!
the backfire didnt happen when I changed up the gears at 4000 rpm but it did at 5500rpm
Thanks in advance!
Old 12-06-2011, 02:03 PM
Thanks in advance!
It's throwing some unburnt fuel out the cylinders on the shift which ignites somewhere inside the exhaust system, not uncommon. The causes can be an over-rich from the carb, or a cylinder being interrupted during its burn by a sudden change in power take off from the crank or a change in RPMs, or it could be at 5500 you're hitting some valve float and an exhaust isn't getting onto or perhaps bouncing off its seat. This condition is usually the spring loosing control thus either allowing the lifter to loft as it goes over the top of the lobe and/or allows the valve bounce when it hits its seat.
Bogie
Old 12-06-2011, 04:27 PM
Thanks for the reply,thinking back I was running a mallory dualpoint,the points gap was not perfect so perhaps it was that! the condensor was the original one as well,I really need to try it now I have put a unilite on it now.
Dont think it was valve bounce,the cam has matching valve springs which have done 600 miles!
Thanks again for your input
Old 12-06-2011, 09:57 PM
sqzbox's Avatar
My pipes are my music
Maybe a rev limiter tach is in your future. Check under the tree on Christmas.
Old 12-07-2011, 12:00 AM
Will do, Seems the summer is a long time away!
Engine Backfire byron74 Engine 2 02-09-2009 09:41 AM
engine backfire jum Engine 3 06-04-2006 04:29 PM
Engine Backfire rosebud48001 Engine 3 03-12-2006 08:10 AM
engine backfire rick6160 Engine 3 03-01-2006 09:44 PM
Engine backfire mychevystang Engine 12 05-02-2005 04:39 PM
