engine backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2006, 01:41 PM
jum jum is offline
engine backfire
454 chevy with a 4 speed.It backfires when I let off the gas. Is this unburned gas igniting? It wont do it if you push the clutch in. Thanks.
Old 06-04-2006, 01:50 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Why would it be back-firing (through the carb) ?
Do you mean exhaust AFTER-firing?
Scavenging is sucking fuel through the engine.
Old 06-04-2006, 02:04 PM
jum jum is offline
Sorry for the lack of info. It sounds like backfire through the headers or pipes. Thanks.
Old 06-04-2006, 05:29 PM
xntrik's Avatar
Ya, excess fuel out the exhaust valve under that high engine vacuum condition. See if you can lean out the idle screws a little and try it again. Might be a delicate balance to achieve. Might also need a tad more vacuum advance to kick in under that high vacuum condition.
We used to coast down, turn off the key, and then turn it on again...... LOL
ruined a couple mufflers and scared the poot out of a bunch of folks...
ah, youth, wasted on the young.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Engine backfire fred56 Engine 3 06-04-2006 12:01 PM
Engine backfire mychevystang Engine 12 05-02-2005 05:39 PM
