Engine Balancing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2013, 04:39 PM
clwhoops44's Avatar
Engine Balancing
I have a rotating assembly for a 383 thats already balanced, but plan on switching out the rods to some Scat i beams that are 14 g lighter than the h beams the kit was balanced with. Will the entire thing need rebalanced? its a street/strip 383.. 450-500 hp/tq
Old 05-08-2013, 07:33 PM
BOBCRMAN@aol.com's Avatar
No, lighter is better. The engine will be slightly "overbalanced" something left turn sportsman racers swear by..
Old 05-08-2013, 09:02 PM
vinniekq2's Avatar
I once and only once in my life,did not balance an engine.
best machine work to do to any engine
Old 05-09-2013, 07:19 AM
In a manner of speaking, Bob is right. It isn't that "cut and dried", though. IF the "big end" of the rod is very close in weight (a gram or two, no more), but the "little end" is where the significant difference is, THAT is "over-balance" and not a bad thing. Itf the big end is much different, it really should be re-balanced. The "rule of thumb" is, you can go about 10% lighter in the reciprocating mass without worries, but not much at ALL in the rotating mass.
I'm pretty much in agreement with Vinnie. We balance them all, for the most part. Only on "bargain rebuilds" or by customer request, do we not.
Jim
Old 05-09-2013, 07:48 AM
Wiki Edits: 27
over balancing
The theory I was told was that when a cylinder Fires it puts more force on the piston and over balancing, having more weight on the crank, can counter act that force.
Old 05-09-2013, 01:05 PM
Overbalance is a one -two percent thing not a lot so 14 grams in the total of piston and rod is probably in the range. But overbalance is for a high RPM wide open throttle operation. On the street crusing under part throttle this will shake. This puts a lot of load into the mains and requires a damn good damper hanging on the front of the crank otherwise the twist moments from the crank shake will cause the nose to wander off center taking the number 1 main with it. Breakage of the snout and/or loss of oil pressure from the number 1 main to the number 1 rod from the main being carved up is a fairly common outcome. By the time you belly up to the bar to buy a supergood damper, you could rebalance the crank and take some weight off the counter balances as well, this makes the engine rev faster.
Bogie
Bogie
Old 05-10-2013, 07:38 AM
Agreed with Bogie, excessive over-balance is a "bad" thing. It goes upwards of 7-8% on high revving blown/alcohol engines. I've seen some big (738s, etc) pro-mod types at 10.
The front main "thing" is generally found in Chevy engines, as the thrust is all the way to the rear. Most engines (American V8s) have thrust on #3, at least one on #4 and another on #1, whidch will have less negative effect on the "end" mains.
FWIW
Jim
Old 05-10-2013, 09:36 AM
engine balance sbc
According to David Vizard up to "50 grams of overbalance can be used before there is a detectable loss of smoothness. More than this the engine shakes more than we like. But it is still likely to be less than a balanced 4 cylinder engine"
"Foregoing balancing does not mean there will be more destructive internal engine loads present. The engine is no more likely to fail than a perfectly balanced engine."
Old 05-10-2013, 11:39 AM
Using a specific "value" in weight applies ONLY to a specific engine. A small block crank weighs about 50 lbs. A big block or Pontiac crank weighs over 70. 50 grams would make a "different" "difference" in these weights. Over-balance should be spoken of in "percentage" unless ALL the parameters are alrready known.
If an engine is far enough "out" of balance, excessive and unusual main bearing wear WILL occur.
FWIW
Jim
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
Engine balancing Hick_101 Engine 4 01-15-2012 02:21 PM
Engine Balancing brainsboy Engine 5 01-26-2008 04:30 PM
balancing an engine elcaminodragster Engine 11 02-21-2007 07:56 AM
What Really Is Engine Balancing? Canadian Charlie Engine 4 12-03-2005 05:34 PM
