engine bay fire help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2008, 03:40 PM
hey guys my cars turbo oil feed split and set the whole bay on fire but was contained in the bay itself
so if i clean bk to bare metal with flap disc whats the best procces to paint the engine bay
many thanks
Old 05-15-2008, 04:18 PM
Holder350's Avatar
Auto Parts Professional
I think paint would be the least of my worries.
wires connectors and electronics would be my first priority.
however.....depending on what it is to bare metal and then a good etching primer then your color is about your only choice.
Old 05-15-2008, 04:59 PM
adtkart@aol.com
The process to paint the engine bay is the same as any other part. Strip it to bare metal. Follow paint manufacturer's directions as far as proper prep to apply epoxy primer. Once it is primed, then you can do whatever you need to get it ready for top coating.
Do not simply use an etch primer.
Aaron
Old 05-15-2008, 10:11 PM
Countilaw's Avatar
Cox Custom Cars
adkart is right, After bare metal, a good coat of epoxy primer followed by top coats. You can use either a single stage or bc/cc system.
Frank
Old 05-16-2008, 09:50 AM
i find it realy hard to get epoxy in scotland paint shops
could i make do with etch??
Old 06-02-2013, 09:52 PM
bodyman
yes but after put on 3 coats of regular primer
Old 06-03-2013, 05:52 PM
Lesonal
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Hiding engine bay wiring, tips, methods? Ripped Electrical 5 12-30-2007 12:02 PM
engine miss fire at high rpm jsteve068 Engine 16 10-04-2005 07:46 PM
Engine Bay paint ffcagle34 Body - Exterior 8 02-21-2004 06:03 PM
Check out the latest engine bay pic.. Rubberman2003 Hotrodders' Lounge 14 09-27-2003 07:31 PM
