you can do an exceptible job using "spray bomb" paint. just remember that all the painting rules still apply. Degrease like crazy,scuff up what you want the paint to stick to. I would suggest removing the hood to help ease access to the fire wall area. Is the engine still in?? If so it will make it more difficult to paint although it can be done. If you can remove the engine it would be a plus. And as to what to tape off?? everything you don't want paint on or hard to clean up overspray on. I have done this kind of dress up before. Just take your time and clean thoroughly.Have fun. Brian
If you don't want to spray, you can brush on POR-15. It will flow out smooth with a very high gloss. It's tough but not UV resistant.
You still have to prep as Brian stated. |
POr-15 rocks!! I forgot about it. It's hard as nails so what ever you put it on it's on for good, and it will stop rust in it's tracks. I think they now have a formula that is ok for UV exposure. http://www.por15.com These people have quality products that I can personally speak for it's quality. And by the way wear gloves. If you get it on your hands you'll wear it for sometime!!!
Under the hood paint/clearcoat
Thanks for the tips guys. My existing engine bay paint quality looks OK, just wanted to add the clearcoat with objective in getting a finish somewhat like exterior. I don't mind using a brush here, either. Is this POR-15 a clearcoat, and if so where is good place to purchase? Many thanks again.
TrainZ28 |
i dont know anything about POR-15
but i suspect u can buy it from a sherwin-williams |
Good ideas, all. Now to decide to go only with the POR-15 clear coat over my SOM 71 code GM paint and hope it will bring out lustre to finish, OR, change colors, go with gloss black, dry, then apply clear coat on top of that. Hmmmm. Since I already have 4 pieces of stainless steel "bling" under the hood, I am thinking about the black option with clearcoat. Firewall already is black. Course, that costs more and takes more time. Life is about trade-offs
, isn't it, guys.......
painting engine compartment
hi, do not mask off the things that you do not want to paint,use aluminum foil(or tin foil) its easy to put on,and easy to take off.my 48 ford coupe chassis was done in POR 15, by the previous owner,i was not impressed,especially after i saw the rust under it. so after i pulled the body off the chassis,i used a 2100 psi pressure cleaner to remove the grease and oil,imagine my surprise,when i blasted about 80% of the por 15 off too. i think its J--K,i will not use it again...Im boatbob2
I am sure that you have to degrease before you apply POR-15. It states in the instructions that you have to remove all the "loose" rust and dirt.
Maybe the previous owner just painted over all the dirt and oil? I got some on the shop floor and it's still there today. Guess that is what happens when you keep the shop floor clean. I've used it and have been very pleased with it. |
| engine paint color code | eneas kid | Engine | 3 | 02-16-2007 08:15 PM |
| How to Paint the Engine Compartment? | abrogard | Body - Exterior | 7 | 10-20-2006 04:06 PM |
| How To Paint An Engine ? ? ? | SCHOONER | Engine | 2 | 10-18-2006 08:05 AM |
| NewB Q about painting engine bay. | BaNe | Hotrodding Basics | 3 | 02-16-2006 07:22 AM |
| engine paint | 78 chevy truck | Engine | 27 | 01-22-2004 04:30 PM |
