engine block codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 07:10 PM
engine block codes
hello all, i am having trouble finding a engine block code, what i have is a 305 chevy was told it was a motor from 1980-- 1984, what im after is the code info stamped on the passenger side front block tab this is what i have is thefollowing KO516C4R,any ideas would help greatly,,,,,,thanks again bad
Old 03-23-2013, 07:57 PM
RWENUTS's Avatar
Check your number again.
C4R is likely wrong. The 4 is likely not right.
Old 03-23-2013, 08:32 PM
block number
hey, just rechecked the number to make sure and yep thats the number plain as day ko516c4r,,,,thanks
Old 03-23-2013, 09:18 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You're correct about the C4R.
K= St. Catherines, Ontario plant
05= May
16= 16th
C4R= 1985 305/150 hp, Rochester E4ME 4 bbl carb
Body style B F/Monte
How to decode Chevy Engine Codes
Semper Fi
Old 03-23-2013, 09:46 PM
block numbers
hey nova , much appreciated, thanks, great site also for the chev specs
Old 03-23-2013, 10:26 PM
RWENUTS's Avatar
I stand corrected. Also shows it as an 82 267.
Old 03-23-2013, 11:00 PM
block numbers
hey guys thanks , its a 5.0 ltr which is 305 as its stamped on the back of the block 14010203 80-84 305,,,,,,thanks again guys
Chevy engine block codes, casting numbers, and specifications Jon Engine 0 03-25-2011 11:06 AM
Ford engine block codes, casting numbers, and specifications Jon Engine 0 01-31-2011 05:26 PM
Block Engine Codes HELP???? Twin Camaro's Introduce Yourself 4 03-28-2008 08:37 PM
small block bowtie engine codes autoverse Engine 3 02-12-2005 06:19 PM
Engine block codes Fordwyochick Engine 6 02-06-2003 02:52 PM
