Engine Block Core Shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2004, 10:30 AM
H2Os50's Avatar
New Member
Hello,
I'm building my first street rod, a '50 Chevy Pickup, and I'm ready to start on the engine.
I have an early '70's 010 4-bolt 350 SBC block (free) that I would like to use. My target is approximately 400HP for this motor. I plan on making this motor a 383 stroker. Not sure yet if it will have fuel injection or a supercharger. This truck will be a driver, not a trailer queen.
My question is with core shift. I have measured the cam bores front and rear and it looks like I have about 0.100" core shift in this area. Is this too much? Should I ditch this block and look for something else? I would hate to spend the machine shop budget on a block that should not have been considered in the first place.
Thanks in advance,
H2Os50
Old 12-24-2004, 02:24 PM
Wiki Edits: 49
Before you ditch the block I would have it sonic checked. This will tell you if the cylinder bores have shifted enough to cause you any problems.
Centerline
Old 12-25-2004, 08:49 AM
H2Os50's Avatar
New Member
Should most good machine shops be able to do this?
Thanks,
H2Os50
Old 12-25-2004, 09:08 AM
Wiki Edits: 49
Absolutely.
Centerline
