Engine block number - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 12:46 PM
Engine block number
Was hoping someone could give me some info. I have an 81 pontiac grand prix. Org had the V-6 and someone dropped a v-8 into it. I think it's the olds 307 but I am not sure. It has the oil tube on the front passengers side as well as the distributer behind the carb and doesn't go through the intake. I found numbers just behind the water pump 3161GM501. Could any please help with any info.
Thanks,
Rob
Old 11-16-2010, 01:45 PM
I also found 5A just about and to the right of the #1 cylinder.
Old 11-16-2010, 03:09 PM
Yes, it's a 1981-88 307. Unfortunately, that's all you can tell from the block casting number, since the same casting was used on all 307s.
Old 11-16-2010, 03:11 PM
It will help to know the number(s) on the cylinder heads next to the No.1 and No. 8 spark plugs. 5A would indicate the larger ports and flat tappet cam used on the 1981-85 307s. 7A indicates the peanut ports and roller cam used from 85-90.
Old 11-16-2010, 05:10 PM
block number
Yeah I checked the one above #8 is 5A as well. Is there much of a difference in parts between the h.o. engines? So with out any other info is there any other way to narrow down the yr of the engine?
Old 11-16-2010, 06:35 PM
The exact year of the BLOCK can be determined from the VIN derivative stamp, located on the driver's side of the block below and slightly forward of the no. 1 exhaust port. The alternator and/or PS pump brackets are usually in the way. The main differences between the 140 HP and 180 HP motors are the cam, carb, and ignition curve in the ECU.
Old 11-17-2010, 05:42 AM
Thank you for the info. I will look later after work and try and find those numbers. Thanks again, Rob.
Old 11-17-2010, 02:34 PM
I checked in the area you mentioned with a mirror and flashlight I didn't see anything. Could it possibly be somewhere else? This w/e I will pull the brackets off. I seen pretty well with the mirror and nothing caught my eye. Also do u have an idea how many digits there should be?
Old 11-17-2010, 03:45 PM
Here's where you'll find the VIN derivative:
Old 11-17-2010, 04:26 PM
I found them. They are rusted up and unreadable. Any ideas on how to pull em out? I was thinking either a piece of paper and pencil and see if they show or taking some black paint wiping it on the area and carefully wiping it off.
Old 11-18-2010, 01:13 PM
Does it really matter? The VIN derivative won't tell you if it's a 140 or 180 HP motor, and the 5A heads tell you it's an 81-85 flat tappet cam motor. Parts are virtually identical over those years. I don't know what else the exact year of manufacture will tell you. You would need to pull the cam and measure it to determine if it's a 140 or 180 HP motor.
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Engine swap, Y block into a '29 Model A pcoghlan General Rodding Tech 5 01-31-2009 08:22 AM
302 chevy engine mess NaythanOldskool Engine 17 12-18-2008 01:04 AM
engine number help carnell Hotrodders' Lounge 2 03-04-2004 11:42 PM
Decipher Block Casting Number rickharris Engine 2 08-28-2002 03:15 PM
