ENGINE, Blower, Pistons, Heads, Carb, Distributor, and more - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2003, 11:54 PM
84Z 84Z is offline
Gas Raper
I have many parts for sale that need to go and I have pictures for everything. Everything is in great condition and is a great buy. Selling because I need funds for a new engine.
Email me at Scorchmaster3000@aol.com if interested
LONG block: 355, 4 bolt main, 2 pc rear seal made in 1984 never used until now, bored, honed mangnafluxed, hot tanked etc. 1 month ago, GM performance forged crank, GM performance forged rods, Keith Black flat top 4 valve relief pistons?, comp cam camshaft and lifters, Chrome moly rods, Performance heads with 2.02/1.6 valves, highflow water and oil pump, chrome oil pan, edelbrock performer intake manifold, steel harmonic balancer (5 hours of ideling to break in everything) internally balanced. Very powerful, similar engine produced 366hp/378 torque, selling $2,000
Hedman ceramic coated inside and out 1 3/4" main 3 1/2" outlet headers full not shorties retail $350 selling $200 (small dent, won't affect performance) no rust perfect condition (20 miles on it)
177 B&M blower perfect condition, comes with manifold, pulleys and everything u need to bolt it on. Teflon still strong, no leaks. (50 miles on it) Retail $2,200 selling $1,400
JE/SRP Low compression pistons nitrous, blower, turbo, and propane ready, made for 350 bored .03 (355) comes with rod pin. (o miles on it, spun rod bearing right after assembly, slightly scuffed but look great) Retail $590 with rings selling $350
Performance heads, 2.02/1.6 valves, manley valves, 76cc chamber heads, Ported and Polished for more air flow, Titanium springs, retainers, rocker arm studs, comes complete. retail "a lot" selling $600 (0 miles on it)
GM Performance HEI Distrib with vac retail (40 miles on it) $300 selling $150
Mr Gasket Hood Scoop retail (50 miles on it, comes with bug blocker, slightly scuffed nothing major) $150 selling $75
750 Dual pumper second vac carb (50 miles on it, still has a lot of life left in it) retail $300 selling $150
