Engine bog when put into drive. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2006, 07:30 AM
Just replaced engine in 1969 Camaro R.S.Engine ran great,decided to check the plugs to see how fuel was burning,plugs looked good.Started the car,put it into reverse and the engine just bogs.Got the car to the street,put into drive and the car fell on it's face and died,restarted,idled o.k. put into drive, bogged down again.Engine runs good with r.p.m.Got back to the house checked the plugs for tightness,checked spark plug wire boots,replaced fuel filter have not checked fuel pressure(but car runs better when r.p.m.'s are up).Plug wires are new(does'nt mean they are good).Running a rebuilt distributer with the Pertronics.600 Holley Avenger carb(replacing this week with a Holley 650).Sorry so much information just trying to nail down all possibilities.Thanks RS69Camaro
Old 07-22-2006, 09:42 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
What trans are you running? sounds like low manifold vacuum
Success is getting what you want but happyness is liking what you get.
Old 07-22-2006, 11:07 AM
I am running a turbo 350.Don't understand why the car ran great after the engine swap.It was'nt until I looked at the plugs on one cylinder head bank that it started acting up.
Old 07-22-2006, 05:03 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Was it the Plugs on Left (Drivers side) Bank? 1 3 5 7...?
Check 5 and 7 for reversed application..that's exactly what it will do...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-22-2006, 09:35 PM
It is on the 2,4,6,8,side.I have a set of Hooker big tube headers so number six is a real pain in the "" to get to.I replaced that spark plug wire tonight and the car seemed to run better.But I took it for a drive , pretty soon realized that it was still not right.Really seems like it is loading up in gear just don't understand how it clears when you put it in park.I have the Holley 600 vac.sec Avenger on it now but I am loosing faith in the carb.Just bought a Holley 650 spreadbore as it will fit the Perfomer intake I am using better.Will change out the carb the first part of the week hopefully that will get rid of the problem.The 650 came with a thick gasket with two small holes in front and two large holes in the back,I just wonder if that is the right gasket for that intake?Thanks
Old 07-24-2006, 11:45 AM
Check and maybe replace your vacuum tubes to the distributor. Your vacuum advance may not be working. Also check to see if the vacuum advance diaphram is good. Do you know how?
Old 07-24-2006, 04:35 PM
Yes thanks.When we set this distributor up it was like it was getting mech advance as well as the vac. advance.We plugged the vac. advance and it ran great.Thanks Randy
Old 07-24-2006, 09:23 PM
O.K. definitely a carb. problem.Suspect big vacuum leak at the baseplate.Changed the Holley 600 to a Holley 650 spreadbore to fit the performer intake and problem solved.Thanks
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 09:11 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Hotrodders Knowledge Base: Engine Jon Engine 0 11-26-2005 07:17 PM
engine turns off when the car is put in to gear t623 Engine 4 02-03-2002 10:23 AM
engine turns off when the car is put in to gear t623 Engine 4 01-24-2002 08:33 PM
