Engine bog at wot and stall at hard brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2017, 05:00 PM
I tried adjusting the floats to cure a stall on heavy braking and it helped but not enough. I have an Edelbrock 650 on a stock crate sbc 350 I adjusted the float to 7/16 up and 15/16 down and if I do a panic stop it kills the engine. Also when I wot sometimes it sputters and seems to bog. I floor it and its like it takes forever to speed up. What's also weird is sometimes at wot the rpm will go up and then jump as if I pushed the pedal harder. What does all this mean? I am considering just taking it to get tuned but this shouldn't be that hard,
Old 03-20-2017, 05:32 PM
hcompton's Avatar
Old & Furious
Mine car did the same thing when it had too much fuel pressure the eddy carbs only like 5 psi max pressure. If you got 6-9 psi it will flood out at wot and when you hit the breaks or take hard sharp turn.
Do you have a pressure gauge and regulator.
Hope this helps.
Old 03-20-2017, 09:14 PM
Hope this helps.
No I don't have a regulator nor have I put a tester on it yet but I do know that my pump shouldn't be pumping that much pressure but then again... Here is the pump I bought. It is a Carter M4685 https://www.summitracing.com/parts/crt-m4685 They claim it maxes out at 6.5 psi and since Edelbrock doesn't recommend going over 6.5psi I thought it would work. I have a Vacuum gauge that says it can test fuel pressure. How can I use this? Just push the end of the gauge's hose into the outlet hose on the pump and clamp it?
Old 03-20-2017, 09:28 PM
hcompton's Avatar
Old & Furious
You need something like this. You can find a cheaper version on ebay if you want.
https://www.summitracing.com/parts/nex-15952
I dont think most eddy carbs are happy with 6.5 psi. I think most may be usable with 5.5 psi but 5 is pretty much the best fuel pressure i have found for the eddy carbs. They will do the flood over with hard turns or hard braking with any amount of pressure over that amount in some cases. Sometimes they are happier with 4.5 psi. Just depends on what your setup likes.
I have also found that most higher flowing fuel pumps put out more pressure than the eddy carbs are happy with. Holley would be fine with the 6.5. They tend to work with a little more pressure than the edelbrock carbs.
I have never seen a vacuum gauge that will also read fuel pressure. I think this would mess up most vacuum gauges. Best to get the one that is mounted under the hood on the carb. Its about the same price and is always there to check the pressure. You cant use them inside the car without and isolator kit since you dont want pressurized fuel in the cabin of the car.
Hope this helps.
runn141's Avatar
yes, i have the same pump for all my edelbrocks and have no problems. i put the gauge on the end of the fuel line an crank it over an they read 5 to 5.5 psi. i buy the pump listed for a 1970 camaro with 307 2 barrel, they are rated at 5 psi.
if your pump reads 5 or 5.5 psi then id say your float drop and level need adjusted. just about everyone ive bought new needed it done.
Old 03-20-2017, 09:36 PM
runn141's Avatar
also i move the rod to the accelerator pump to the bottom hole. i know the book says thats less fuel but it took the bog out of a couple i had.
WOT @ Idle = Bog. Why? SJSS Engine 7 07-23-2012 07:59 AM
Help with engine bog ?? robbie43 Engine 9 02-29-2012 01:22 AM
200 4r TV cable - no WOT, hard 1-2, no kickdown 60smotorhead Transmission - Rearend 27 07-28-2009 05:24 AM
engine stall with brake pedal corvettetonybone Electrical 13 04-21-2009 05:37 PM
Edelbrock 750cfm, Bog at quick WOT NoEgoMan100 Hotrodding Basics 8 06-05-2006 05:43 PM
