engine bolt hole to bellhousing is broken, is it ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 10:36 PM
Post engine bolt hole to bellhousing is broken, is it ok?
I've got a 302 that I was planning on rebuilding, but during the process, I noticed that on the engine, one of the bolt holes where the bellhousing bolts on is broken. The broken one is on the left side of the block, furthest from the starter. Its a 6-bolt bellhousing.
Will this be a problem? I was planning on taking this block to a machine shop tomorrow, but if this is a big enough problem, I'll save myself the time and just get something else.
Old 11-06-2002, 04:18 AM
slider in wa's Avatar
Slider in Wa.
Post
This a ford 302? I don`t see why you can`t weld the broken peice back on and have it machined/ ground down.
Slider in Wa.
Old 11-06-2002, 10:54 AM
Post
That sounds like a completely reasonable thing to do, but the problem is that I don't have the piece that broke off.
Old 11-06-2002, 01:07 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
If it's one of the bottom bolts, I still wouldn't think it would hurt. Is this gonna' be a racer? I have left upper bolts out many times with no problems (Did I say that? ). Hey, thats one for the "Hotrod dictionary"!
OPTIONAL EQUIPMENT: Those left over bolts and brackets after a job is done.
Old 11-06-2002, 01:58 PM
New Member
Post
I don't think it's a big problem. Why don't you take it to the machine shop and ask them?
Old 11-06-2002, 02:47 PM
woodz428's Avatar
Troll Hunter
Thumbs up
I wouldn't think it to be a problem, I've used bell housings and know a guy that used a top loader with one broken hole ( the top loader was behind a big block Chevy in a drag car).
Old 11-06-2002, 05:25 PM
Post
I took it to a machine shop, he said it was ok. Thanks for the responses =)
